Its simple, download the firmware file, rename it, copy to sd card, put into aircraft and power it on.
Detailed steps:
1. Download the proper file for your aircraft and firmware version. Choose wisely. -> https://github.com/digdat0/P3I1_FWProject
The file you are downloading is the 306.bin file, like P3X_FW_V01.11.0020_m0306.bin_MODDED
2. Rename the downloaded file.
Phantom 3 = PMCAPPFw3.bin
Inspire 1 = INMCAPPFw1.bin
3. Copy the file to your SD card. Put SD card into the aircraft.
4. Power on the aircraft. Update will start in about 30 seconds. You will hear a distinct noise during the update process, which will change when done. It should take 3-5 minutes.
** If the update does not start, please turn off aircraft. Press and hold the bind button, and turn back on. Hold this button for 20-30 seconds and the update will start and will make a beeping noise, then you can let go and let the update finish.
5. When update is done, power off the aicraft. Remove the SD card from the camera and back into the computer
6. Remove/ Delete the "PMCAPPFw3.bin_updated" or "INMCAPPFw1.bin_updated" file from the SD card Note: If the file is "PMCAPPFw3.bin_damaged" or "INMCAPPFw1.bin_damaged" the update did not complete, retry it.
7. Put Sd card back in the camera
All done! On your next startup, the modifications will persist on the aircraft. They will remain until you reflash the stock firmware.
Free Firmware for I1 and P3
- Bruchpilot
- Hat sich bedankt: 0
Zurück zu „Inspire 1 / Phantom 3“
Gehe zu
- INFO
- ↳ Information
- DJI Kopter
- ↳ Phantom 1
- ↳ Phantom 2
- ↳ Phantom 2
- ↳ Phantom 2 Vision
- ↳ Phantom 2 Vision+
- ↳ Phantom 3
- ↳ Phantom 3 Standard
- ↳ Phantom 3 Advanced & Professional
- ↳ Phantom 4
- ↳ Inspire
- ↳ Inspire 1
- ↳ Inspire 2
- ↳ FlameWheel F330 / F450 / F550
- ↳ FlameWheel F450 / F550
- ↳ Spreading Wings S800, S900, S1000
- ↳ DJI - betrifft mehrere Systeme
- ↳ Matrice 200
- ↳ Matrice 600
- ↳ Mavic
- ↳ Spark
- ↳ DJI Neuheiten
- ↳ DJI Racing Drone
- Yuneec Kopter
- ↳ Q500 Serie
- ↳ Q500
- ↳ Q500+
- ↳ Q500 G
- ↳ Q500 4k
- ↳ ST10 , ST10+
- ↳ Tpyhoon H
- ↳ Sonstige Yuneec Kopter
- Racer
- ↳ Emax Nighthawk
- ↳ Andere Hersteller
- Gaui Kopter
- ↳ Gaui 840H
- ↳ Andere
- Graupner Kopter
- ↳ Graupner Alpha 250Q mit GR-18 FC
- ↳ Graupner Hornet 250 Tricopter mit GR-18 FC
- ↳ Graupner Sweeper Droneball
- drone-hacks (dji)
- ↳ English area - https://drone-hacks.com/
- ↳ General Chat
- ↳ Mod Client
- ↳ Tips & Tricks
- ↳ Feature Requests
- ↳ Drone Model specific
- ↳ Mavic
- ↳ Mavic 2
- ↳ Mavic 2 Enterprise
- ↳ Mavic Air
- ↳ Mavic Air 2
- ↳ Mavic mini
- ↳ Sparc
- ↳ Phantom 4
- ↳ Phantom 4 pro v2.0
- ↳ Inspire 2
- ↳ Inspire 1 / Phantom 3
- ↳ Other
- ↳ Global Hawk
- ↳ Deutschsprachiger Bereich - https://drone-hacks.com/
- ↳ Allgemein
- ↳ Mod Client
- ↳ Tip's & Tricks
- ↳ Gewünschte Erweiterungen
- ↳ Vom Kopter Model abhängig
- ↳ Mavic
- ↳ Mavic 2
- ↳ Mavic Air
- ↳ Mavic Air 2
- ↳ Mavic Air mini
- ↳ Sparc
- ↳ Phantom 4
- ↳ Inspire 2
- ↳ Andere
- andere Hersteller und Modelle sowie selbstgebaute Kopter
- ↳ Eigene Konstruktionen - Selbstgebaut
- ↳ andere Hersteller & Modelle
- Allgemeiner Bereich
- ↳ Benutzervorstellung
- ↳ Treffen und Veranstaltungen
- ↳ Raum Plz 0
- ↳ Raum Plz 1
- ↳ Raum Plz 2
- ↳ Raum Plz 3
- ↳ Raum Plz 4
- ↳ Raum Plz 5
- ↳ Raum Plz 6
- ↳ Raum Plz 7
- ↳ Raum Plz 8
- ↳ Raum Plz 9
- ↳ Österreich
- ↳ Schweiz
- ↳ Andere Länder
- ↳ Klatsch und Tratsch
- ↳ Mit demKopter aufgenommen - Fotos
- ↳ Mit dem Kopter aufgenommen - Filme
- ↳ Pressespiegel
- Fachsimpeln
- ↳ Gesetze und Vorschriften
- Technik
- ↳ Flug Kontroller ( FC )
- ↳ DJI Naza
- ↳ DJI A2
- ↳ DJI A3
- ↳ DJI Wookong
- ↳ SP Racing F3 & F4 mit Cleanflight / Betaflight
- ↳ DJI Motoren Set's - Antriebssysteme E300, E305, E310, E800 etc.
- ↳ Technik allgemein, was nirgendwo anders passt.
- ↳ Antennen Technik
- ↳ FPV
- Kopter Schulung
- Marktplatz - Angebote von Usern
- ↳ Anleitung - Regeln - Hinweise
- ↳ 3D Drucke
- ↳ Kopter - Kopter Bausätze
- ↳ Kopter Zubehör - Ersatzteile
- ↳ Stromversorgung Ladegeräte / Batterien
- ↳ Fernsteuer Sender / Empfänger
- ↳ Auftragsflüge (gewerblich)
- ↳ Sonstiges
- THW OV Viersen
