Bug in Firmware, Mavic , Inspire 2 u. Phantom 4 Pro
DJI hat offensichtlich einen oder mehre Bugs in der neuen Firmware für dem Mavic, Inspire 2 und den Phantom 4 Pro. Litchi hat eine entsprechende Warnung herausgegeben.
Dear Litchi Pilots,
There is currently an issue with the recently released firmwares for Mavic Pro (v01.03.0500), Inspire 2 (v01.0.0240) and Phantom 4 Pro (v01.03.0418) where the drone will fly erratically in some of Litchi’s flight modes. If you already installed one of these firmwares, we highly recommend not using these flight modes until the issue is fixed with a DJI firmware update. The following flight modes are affected: VR with Immersive/Joystick Head Tracking active, Follow, Focus and Track. All other flight modes (including FPV, Waypoint, Orbit and VR with Immersive/Joystick Head Tracking OFF) are unaffected.
The Litchi Team
Re: Bug in Firmware, Mavic , Inspire 2 u. Phantom 4 Pro
#2 Beitrag von dieterste36 »
Andere Firmen warnen auch. Da DJI auch seine eigenen SDK Module in der Go App verwendet, dürfte die Go App das gleiche Problem haben.
Current Issues
There is currently an issue with the latest DJI firmware for the Mavic Pro, Phantom 4 Pro and Inspire 2 which causes erratic flight behavior in Autopilot. We do not recommend* using Autopilot with these aircraft types until a resolution has been found for this issue. If you are using firmware 01.03.0200 or below, you should not see these issues.
* It is still possible to safely use Human Flight Control Modes and Waypoint Mode as long as Lost Connection is set to Continue Mission (LCMC).
We will send out another correspondence when this issue has been resolved.
Thanks for your understanding!​
The Hangar Team
